Creates a search path for the run/load script filename command.
.| path | Defines the colon-separated list of directories to search for CLI scripts. Default is .:/usr/local/cfg. |
.:/usr/local/cfg
This setting only applies to the current session. This command must be added to exshrc.xsf in order to be persistent.
The following example configures the default script search path:
configure cli script path
This command was first available in ExtremeXOS 31.4.
